AirWave and Network Management
AP's stuck in planned status in VisualRF
I have two AP's that are stuck in planned mode. They appear fine in both my controller and in the APs/Devices list. How do I get them out of Planned status?
Moderator
Re: AP's stuck in planned status in VisualRF
To be sure, are you able to find the actual APs being monitored/managed in AMP? If so, then you can right click on the planned AP for a menu list. There should be a 'Match with Managed AP' option that will bring a drop down list of the available APs. Choose the desired AP from the pull down.
-Rob
AirWave Support
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
That worked perfectly. Thanks.
