AirWave and Network Management
Add custom links to Airwave
We have some documents with local info about Airwave. We would like our users to be able to access the documents by a link in Airwave.
Is it possbile to add custom links to "Home -> Documents"? And will the page be reset when we upgrade Airwave?
Regular Contributor I
Our support team can help you create a patch that will add the links to
the Home Documentation page, but the page will get reset when you
upgrade the software.
Being able to add custom content to the documentation page is a great
idea, and it would make a great request at
Re: Add custom links to Airwave
It wasn't exactly on the documentation page but we had a similar thread earlier i used to make a custom master console public portal front end page. Jason's input was very helpful in getting it working.
