AirWave and Network Management
AirWave Management Platform XML API
I was wondering if there is a way to push/configure some general properties of an AP like its name etc. from AirWave Management Platform's XML API. I haven't had any luck so far with the available documentation.
Can someone help me with the same?
Thank you.
Re: AirWave Management Platform XML API
What platform do you want pushing to what? Do you want to send commands to Airwave and then Airwave sends commands to the controller?
Colin Joseph
Aruba Customer Engineering
Yes, I want to send commands to AirWave using the api and AirWave then sends them to the controller.
7240 Controller to the 220/225 AP.
I would like to use the Airwave API as well.  I've found the documentation for the xml files to query and all that and know which ones I need to use, but I cannot for the life of me figure out how to get a remote server to access them using a program that I write.  The remote program is going to need to authenticate to airwave somehow, but it is not documented anywhere that I can find.
I did find this post that mentioned authenticating to airwave (, however the link referenced in that post is a 404.
