AirWave and Network Management
Super Contributor I
Airwave SCP backup script
All,
I've attached a TCL / Expect script that will SCP the nightly backup off of an Airwave server. To use this script, unzip the file and remove the "-generic" extension. There are in-line commands that should help get it running properly on your Airwave server.
I tuned up the script over the past couple of days to include a server name ( for multi-server installations ) and to append a version number, not just a date.
Let me know what you think and let me know how you would improve the script.
Thanks!
-Mike
I'm also appending the code:
#!/usr/bin/expect -f
## Name: Mike Courtney
## Institution: Washington and Lee University
## Date: 2/19/2011
## Function: This program will scp a copy of the most recent Airwave database to a backup server
## Execution: ./airwave-backup.sh
## Execution example: ./airwave-backup.sh /var/airwave-backup/nightly_data001.tar.gz
## Location: I have placed the program in the /root directory
## Permissions: chmod 700 root:root airwave-backup.sh
## Crontab: The following crontab entry will run every morning at 6am:
## 00 06 * * * root /root/airwave-backup.sh /var/airwave-backup/nightly_data001.tar.gz
## Run the following command after the change: /etc/init.d/crond restart
## Run the following command from the shell to determine the location of expect:
## which expect
## Example output:
## # which expect
## /usr/bin/expect
## The first line of the program may need to be modified if the expect
## location is differnet.
## Run the following command if expect is not installed on the Airwave server:
## yum install expect
## MAIN PROGRAM
set ampBackupFile
set timeout -1
## VARIABLES
## These individual variables should be tailored to your specific environment
set userName "yourusername"
set userPassword "yourpassword"
set backupServer "server.domain.com"
set backupServerPath "/home/yourusername/directory"
set ampVersionPath "/usr/local/airwave/bin/"
## This is the name of the file as it will appear on the remote server
set backupFile "-nightly_data--.tar.gz"
## Backup file example: airwave-nightly_data-7.2.1-02192011.tar.gz
## END VARIABLES
## TESTING
## Remove the pound (#) symbol from the below command to test your output.
## Remember to also place a pound in front of the code in the "BEGIN SCP" section
#puts "$ampBackupFile $userName@$backupServer:$backupServerPath/$backupFile"
## END TESTING
## BEGIN SCP
## This will run the scp command
spawn scp $ampBackupFile $userName@$backupServer:$backupServerPath/$backupFile
## These are the specific expect commands to complete the SCP to the backup server
expect {
password: {send "$userPassword\r" ; exp_continue}
eof exit
## END SCP
## END OF MAIN PROGRAM
Regular Contributor I
Re: Airwave SCP backup script
That's a great script!
You can also copy or symlink the script to /var/airwave/custom/post_nightly_maintenance and then hardcode the AMP backup file name. That script will run after nightly maintenance (the process that creates the backup) finishes each morning.
There's a similar script posted at https://airheads.arubanetworks.com/vBulletin/archive/index.php/t-1135.html that uses SSH keys instead of a password.
