Aruba VIA client
Good morning
i need some help about VIA client
1) why client given mask of 255.255.255.255
2)how can i give VIA client IP related to a defined controller VLan
Re: Aruba VIA client
You would just edit the ipsec pool to change the range that the client gets. In the VPN client termination world, the subnet mask is sort of meaningless.
thank you for your help i try it and it works wELL
