CLI command
Good morning
I have AP Rap 5 and i want to enter to CLI mode of it
thanks in advance
Re: CLI command
There is no access to the CLI on the RAP5 until it gets connected to the controller.
Colin Joseph
Aruba Customer Engineering
Re: CLI command
OK thank you :D:D
