DNS with via
Hi all i know how to configure the controller to have one IP and the via client sense it
how can i configure it to use DNS such that i put 2 or more ips in the DNS and then
write this DNS on the connection of via client so if it didnt find the first ip it wil switched automatically to 2nd and so on
thanks in advance
Re: DNS with via
That would be in the l2tp settings in VPN.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Re: DNS with via
Thanks for your help but i don't mean that
I mean that how can i made domain name for example Aruba333.com and this domain mapped automatically to certain ip or ips .
thanks in advance
Contributor I
Re: DNS with via
thanks in advance
Not sure if i completely understand your questions/request but I think you are asking how can your VIA client use DNS to resolve one hostname with two different ip addresses.
As mentioned in the post, you assign the DNS server that the VIA clients receive in the VPN Services tab. In your case that seems like it should be one of your INTERNAL DNS server that you have the ability to make chnages on.
You can configure your DNS server to reply with multiple IPs for the same hostname (DNS round robin) BUT MOST DNS server do not have the ability to know if the IPs are available.
hope this helps...
Re: DNS with via
Ok thank you for help .
