AirWave and Network Management
Do you administer RF Plan and Visual RF?
When using Airwave and deploying new APs to you modify the RF Plan on the controller as well as Visual RF within AMP or just concern yourself with AMP?
Re: Do you administer RF Plan and Visual RF?
I just use Visual RF, no need to clutter the controllers with that.
