AirWave and Network Management
Contributor I
Groups client
Is it possible to customer groups? Now we have an Airwave with many groups, each group is a cross.
Regards
Aruba
Re: Groups client
Yes...you can configure role based access for Airwave.  Here's the user guide:
http://support.arubanetworks.com/DesktopModules/Bring2mind/DMX/Download.aspx?TabId=77&DMXModule=512&Command=Core_Download&EntryId=11482&PortalId=0&__gda__=1380127912_3f0218dc9e19050b009693bd415b5834
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
Contributor I
Re: Groups client
Thanks... but my idea is to have client groups to have them monitored. In the guide I find the right solution. That data would take of my clients? MAC?
Regards
