AirWave and Network Management
Identifying users post src-nat
We periodically receive copyright notifications from the RIAA/MPAA about students on our network bittorrenting illegal stuff. We have our controller setup to src-nat user traffic (via Configuration->IP->Edit the VLAN->Enable source NAT for this VLAN, *not* via a firewall rule). When we get the notice it gives us src-natted IP/port (ie, the controller's IP address). Example:
Evidentiary Information:
> Notice ID: abignumber
> Asset: GLEE
> Protocol: BitTorrent
> IP Address: xx.xx.xx.xx
> DNS: aruba-master.domain.com
> Port ID: 3382
> File Name: Glee.S02E02.HDTV.XviD-LOL.avi
> File Size: 366752408
> Timestamp: 2010-11-01 01:14:45.560 GMT
> Last Seen Date: 2010-11-01 01:14:45.560 GMT
where xx.xx.xx.xx is the public IP of aruba-master.domain.com. What we need to be able to do is correlate that natted IP/port to the original user that committed the offense. Does anyone know how to do that? Complicating the issue is that we often receive the notice several days after the actual offense. We have AirWave setup and running if that helps anything.
Thanks for the help.
Re: Identifying users post src-nat
There's no way to tell today who the user was.
If instead of the "ip nat inside" method of natting users, you make the firewall policy to nat user traffic to a pool and log it. Once you do that, we log the NAT like this:
If you send these logs to a syslog server, it is indeed searchable. You can search the logs for that destination ip address (in this case 209.85.133.190) and it will reveal the time and ip address of the user. You can search airwave for the ip address and it will tell what user had the ip address at the time. Cumbersome, possibly, but hopefully you do not have to do it often.
The problem is we don't get a dest-ip with the notice (I assume they want to keep the IP's they use at least somewhat secret). The only usable thing to search for would be src-port since nat will (if at all possible) not change that. The problem is, sometimes that src-port will change if there would otherwise be a conflict making the process cumbersome and unreliable. Another issue is that the timestamp in syslog would be from the initial connection while the timestamp in the notice would be from sometime during the transaction. We would need to search for the most recent occurrence of the src-port before the timestamp in the notice (again, doable but cumbersome and hardly reliable).
Maybe a better way to solve this is to block bittorrent as best we can. Anyone have a suggestion on how to do that? In the past when I've tried the clients just start using SSL on port 443 and then I can't do anything about it. Ideas?
The log message has the port:
action=src-nat 192.168.254.16/54569
If you want to block bittorrent, you should have a packet shaper do that specific function and the Natting if you want increased visibility.
It has the pre-nat src-port. Normally that will be the same but the natting rules will change the src-port if they need to in order to avoid port collisions.
You are right. Without a destination address, how can they even expect you to determine who did what and when?
