AirWave and Network Management
Contributor II
Printing VisualRF heat maps
How do I print the VisualRF heat maps? I'm using 7.3.6. I trying to print them to show my boss where our "holes" are in our wireless network is in out Campus Library. I also can't find where I can delete a building or rename. I think one of the earlier versions was a lot easier to use. Any help would be appreciated.
Regular Contributor I
If you right-click on a building or campus, you can choose to export a Bill of Materials report, which will include heatmaps suitable for printing.
Moderator
Re: Printing VisualRF heat maps
Right clicking on a campus or building will also give you the option to delete a campus or building. That functionality hasn't changed in a long time.
What previous version of VisualRF did you find easier to use?
Contributor II
Thanks. I found 3.0 the easiest to use. Just started using 7.3. I usually do passive wireless designs but would like the use the RF tools complete with heat map drawings. I'm finding the heat maps are very close to the actual coverage.
Moderator
There were some significant changes between RF Plan 3 and VRF Plan 7.3. We tried very hard to make the process of planning a site easier and faster. Hopefully the learning curve won't be too tough.
The AirWave user guide available from the documentation section of the support page, http://support.arubanetworks.com/DOCUMENTATION/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=6099, has a lot of information in the Using VisualRF section. The Planning and Provisioning section is about 10 pages long and would be good to review.
