AirWave and Network Management
RF Planning with Airwave
Is anyone doing RF Planning with Airwave? I just stumbled over that capability recently. I did not know it existed.
Really?
I'd love to do planning with Airwave, but I didn't think it had the capability. Are you doing this with VisualRF?
VisualRF does RF Planning
VisualRF does RF planning quite well. If you have access to it, it's absolutely worth trying.
RF Planning with VisualRF
I have been using alot. It is flexible, can import RF plans from the Aruba Controller or offline RF planning tool and can also select areas that are not perfect squares with ease. It also as a "Bill of Materials" function which can produce a bill of materials of all the APs that you have in a building, for example.
Re: RF Planning with Airwave
Oh wow, yeah, I just checked the docs on how to do RF planning in Visual RF...that is sweet! Really nice, thanks for starting this thread Colin, who knows when I would have stumbled upon that!
Using Visual RF
Are you using it to monitor multiple-vendor WLANs, or just one?
No, just Aruba...what other WLAN providers are there? ;)
VisualRF currently supports planning for
- Aruba
-Cisco
-Symbol
-HP
Also, another really cool feature that VisualRF has for planning is the two modes; Manual Planning and Auto Provisioning.
Manual Planning - will allow the user to manually place individual AP's in specific positions on a floorplan and display the predictive coverage.
Auto Provisioning - allows the user to define a polygon shaped region and specify the desired datarate and coverage, and VisualRF will populate the desired number of AP's to match the specified requirements.
