Frequent Contributor I
SNMP Trap Filter
is it possible to limit the number of SNMP Traps that are being send by the controller?
Thank you and best Regards
Re: SNMP Trap Filter
On the commandline, first do "show snmp trap-list" to see what you are working with:
You can then do a "config t snmp-server trap disable " Tip: The snmp trap names ARE case-sensitive. You can then do "show snmp trap-queue" to see what is being sent out.
(McGraw-Hill) #show snmp trap-list
SNMP TRAP LIST
TRAP-NAME CONFIGURABLE ENABLE-STATE
authenticationFailure Yes Enabled
coldStart Yes Enabled
linkDown Yes Enabled
linkUp Yes Enabled
warmStart Yes Enabled
wlsxAPBssidEntryChanged Yes Enabled
wlsxAPChannelChange Yes Enabled
wlsxAPDeauthContainment Yes Enabled
wlsxAPEntryChanged Yes Enabled
wlsxAPImpersonation Yes Enabled
wlsxAPInterferenceCleared Yes Enabled
wlsxAPInterferenceDetected Yes Enabled
wlsxAPModeChange Yes Enabled
wlsxAPPowerChange Yes Enabled
wlsxAPRadioAttributesChanged Yes Enabled
wlsxAPRadioEntryChanged Yes Enabled
wlsxAPSpoofingDetected Yes Enabled
wlsxAPTaggedWiredContainment Yes Enabled
wlsxAPWiredContainment Yes Enabled
wlsxAccessPointIsDown Yes Enabled
wlsxAccessPointIsUp Yes Enabled
wlsxAdhocNetwork Yes Enabled
wlsxAdhocNetworkBridgeDetected Yes Enabled
wlsxAdhocNetworkBridgeDetectedAP Yes Enabled
wlsxAdhocNetworkBridgeDetectedSta Yes Enabled
wlsxAdhocNetworkDetected Yes Enabled
wlsxAdhocNetworkRemoved Yes Enabled
wlsxAdhocUsingValidSSID Yes Enabled
wlsxApFloodAttack Yes Enabled
wlsxAuthMaxAclEntries Yes Enabled
wlsxAuthMaxBWContracts Yes Enabled
wlsxAuthMaxUserEntries Yes Enabled
wlsxAuthServerIsUp Yes Enabled
wlsxAuthServerReqTimedOut Yes Enabled
wlsxAuthServerTimedOut Yes Enabled
wlsxBSSIDIsDown Yes Enabled
wlsxBSSIDIsUp Yes Enabled
wlsxBlockAckAttackDetected Yes Enabled
wlsxCRLExpired Yes Enabled
wlsxCTSRateAnomaly Yes Enabled
wlsxCTSTransferError Yes Enabled
wlsxCTSTransferSucceeded Yes Enabled
wlsxChannelChanged Yes Enabled
wlsxChannelFrameErrorRateExceeded Yes Enabled
wlsxChannelFrameFragmentationRateExceeded Yes Enabled
wlsxChannelFrameRetryRateExceeded Yes Enabled
wlsxChannelInterferenceCleared Yes Enabled
wlsxChannelInterferenceDetected Yes Enabled
wlsxChannelMisconfiguration Yes Enabled
wlsxChannelRateAnomaly Yes Enabled
wlsxChopChopAttack Yes Enabled
wlsxClientAssociatingOnWrongChannel Yes Enabled
wlsxClientDeauthContainment Yes Enabled
wlsxClientFloodAttack Yes Enabled
wlsxClientTaggedWiredContainment Yes Enabled
wlsxClientWiredContainment Yes Enabled
wlsxColdStart Yes Enabled
wlsxConfigurationLicenseMismatch Yes Enabled
wlsxConfigurationUpdateError Yes Enabled
wlsxConfigurationUpdateSucceeded Yes Enabled
wlsxCoverageHoleDetected Yes Enabled
wlsxCoverageHoleResolved Yes Enabled
wlsxDBCommunicationFailure Yes Enabled
wlsxDisconnectStationAttack Yes Enabled
wlsxDisconnectStationAttackAP Yes Enabled
wlsxDisconnectStationAttackSta Yes Enabled
wlsxEAPRateAnomaly Yes Enabled
wlsxESIServerDown Yes Enabled
wlsxESIServerUp Yes Enabled
wlsxEsiServerChanged Yes Enabled
wlsxFanFailure Yes Enabled
wlsxFanOK Yes Enabled
wlsxFanTrayInserted Yes Enabled
wlsxFanTrayRemoved Yes Enabled
wlsxFataJackAttack Yes Enabled
wlsxFlashSpaceOK Yes Enabled
wlsxFrameBandWidthRateExceeded Yes Enabled
wlsxFrameFragmentationRateExceeded Yes Enabled
wlsxFrameLowSpeedRateExceeded Yes Enabled
wlsxFrameNonUnicastRateExceeded Yes Enabled
wlsxFrameReceiveErrorRateExceeded Yes Enabled
wlsxFrameRetryRateExceeded Yes Enabled
wlsxGBICInserted Yes Enabled
wlsxGlobalConfigurationChangeNotification Yes Enabled
wlsxHT40MHzIntoleranceAP Yes Enabled
wlsxHT40MHzIntoleranceSta Yes Enabled
wlsxHotspotterAttackDetected Yes Enabled
wlsxHtGreenfieldSupported Yes Enabled
wlsxInRangeVoltage Yes Enabled
wlsxInformQueueOverFlow Yes Enabled
wlsxInterferingApDetected Yes Enabled
wlsxInvalidAddressCombination Yes Enabled
wlsxInvalidMacOUIAP Yes Enabled
wlsxInvalidMacOUISta Yes Enabled
wlsxIpSpoofingDetected Yes Enabled
wlsxLCInserted Yes Enabled
wlsxLCRemoved Yes Enabled
wlsxLicenseEntryChanged Yes Enabled
wlsxLicenseExpiry Yes Enabled
wlsxLoadbalancingDisabled Yes Enabled
wlsxLoadbalancingEnabled Yes Enabled
wlsxLowMemory Yes Enabled
wlsxLowOnFlashSpace Yes Enabled
wlsxMalformedAssocReqDetected Yes Enabled
wlsxMalformedAuthFrame Yes Enabled
wlsxMalformedFrameLargeDurationDetected Yes Enabled
wlsxMalformedFrameWrongChannelDetected Yes Enabled
wlsxMalformedHTIEDetected Yes Enabled
wlsxMemoryUsageOK Yes Enabled
wlsxMeshNodeEntryChanged Yes Enabled
wlsxMgmtUserAuthenticationFailed Yes Enabled
wlsxMonAPEntryChanged Yes Enabled
wlsxMonStationEntryChanged Yes Enabled
wlsxNAPMasterStatusChange Yes Enabled
wlsxNAccessPointIsDown Yes Enabled
wlsxNAccessPointIsUp Yes Enabled
wlsxNAdhocNetwork Yes Enabled
wlsxNAdhocNetworkBridgeDetectedAP Yes Enabled
wlsxNAdhocNetworkBridgeDetectedSta Yes Enabled
wlsxNAdhocUsingValidSSID Yes Enabled
wlsxNApOnBackupController Yes Enabled
wlsxNAuthMaxAclEntries Yes Enabled
wlsxNAuthMaxBWContracts Yes Enabled
wlsxNAuthMaxUserEntries Yes Enabled
wlsxNAuthMaxXsecUserEntries Yes Enabled
wlsxNAuthServerAllInService Yes Enabled
wlsxNAuthServerIsDown Yes Enabled
wlsxNAuthServerIsUp Yes Enabled
wlsxNAuthServerReqTimedOut Yes Enabled
wlsxNAuthServerTimedOut Yes Enabled
wlsxNChannelChanged Yes Enabled
wlsxNConnectionResetWithLocal Yes Enabled
wlsxNCoverageHoleDetected Yes Enabled
wlsxNDBCommunicationFailure Yes Enabled
wlsxNDisconnectStationAttack Yes Enabled
wlsxNESIServerDown Yes Enabled
wlsxNESIServerUp Yes Enabled
wlsxNFanFailure Yes Enabled
wlsxNFanTrayInserted Yes Enabled
wlsxNFanTrayRemoved Yes Enabled
wlsxNGBICInserted Yes Enabled
wlsxNInterferingAPDetected Yes Enabled
wlsxNIpSpoofingDetected Yes Enabled
wlsxNLCInserted Yes Enabled
wlsxNLCRemoved Yes Enabled
wlsxNLicenseExpiry Yes Enabled
wlsxNLowMemory Yes Enabled
wlsxNLowOnFlashSpace Yes Enabled
wlsxNOutOfRangeTemperature Yes Enabled
wlsxNOutOfRangeVoltage Yes Enabled
wlsxNPowerSupplyFailure Yes Enabled
wlsxNPowerSupplyMissing Yes Enabled
wlsxNProcessDied Yes Enabled
wlsxNProcessExceedsMemoryLimits Yes Enabled
wlsxNRadioAttributesChanged Yes Enabled
wlsxNRapExpiredPSK Yes Enabled
wlsxNRapWarnExpiredPSK Yes Enabled
wlsxNRogueAPDetected Yes Enabled
wlsxNRogueAPResolved Yes Enabled
wlsxNSCInserted Yes Enabled
wlsxNSignatureMatch Yes Enabled
wlsxNSignatureMatchAirjack Yes Enabled
wlsxNSignatureMatchAsleap Yes Enabled
wlsxNSignatureMatchDeauthBcast Yes Enabled
wlsxNSignatureMatchDisassocBcast Yes Enabled
wlsxNSignatureMatchNetstumbler Yes Enabled
wlsxNSignatureMatchNullProbeResp Yes Enabled
wlsxNSignatureMatchWellenreiter Yes Enabled
wlsxNStaUnAssociatedFromUnsecureAP Yes Enabled
wlsxNStationAddedToBlackList Yes Enabled
wlsxNStationRemovedFromBlackList Yes Enabled
wlsxNSuspectRogueAPDetected Yes Enabled
wlsxNSuspectRogueAPResolved Yes Enabled
wlsxNSwitchIPChanged Yes Enabled
wlsxNSwitchRoleChange Yes Enabled
wlsxNUserAuthenticationFailed Yes Enabled
wlsxNUserEntryAuthenticated Yes Enabled
wlsxNUserEntryCreated Yes Enabled
wlsxNUserEntryDeAuthenticated Yes Enabled
wlsxNUserEntryDeleted Yes Enabled
wlsxNVpnMaxSessions Yes Enabled
wlsxNVrrpStateChange Yes Enabled
wlsxNeighborAPDetected Yes Enabled
wlsxNodeRateAnomaly Yes Enabled
wlsxNodeRateAnomalyAP Yes Enabled
wlsxNodeRateAnomalySta Yes Enabled
wlsxNormalTemperature Yes Enabled
wlsxOUIMisconfiguration Yes Enabled
wlsxOmertaAttack Yes Enabled
wlsxOutOfRangeTemperature Yes Enabled
wlsxOutOfRangeVoltage Yes Enabled
wlsxOverflowEAPOLKeyDetected Yes Enabled
wlsxOverflowIEDetected Yes Enabled
wlsxPortDown Yes Enabled
wlsxPortEntryChanged Yes Enabled
wlsxPortUp Yes Enabled
wlsxPowerSaveDosAttack Yes Enabled
wlsxPowerSupplyFailure Yes Enabled
wlsxPowerSupplyMissing Yes Enabled
wlsxPowerSupplyOK Yes Enabled
wlsxProcessDied Yes Enabled
wlsxProcessExceedsMemoryLimits Yes Enabled
wlsxProcessRestart Yes Enabled
wlsxRTSRateAnomaly Yes Enabled
wlsxRepeatWEPIVViolation Yes Enabled
wlsxReservedChannelViolation Yes Enabled
wlsxSCInserted Yes Enabled
wlsxSCRemoved Yes Enabled
wlsxSSIDMisconfiguration Yes Enabled
wlsxSequenceNumberAnomalyAP Yes Enabled
wlsxSequenceNumberAnomalySta Yes Enabled
wlsxShortPreableMisconfiguration Yes Enabled
wlsxSignAPAirjack Yes Enabled
wlsxSignAPAsleap Yes Enabled
wlsxSignAPDeauthBcast Yes Enabled
wlsxSignAPNetstumbler Yes Enabled
wlsxSignAPNullProbeResp Yes Enabled
wlsxSignStaAirjack Yes Enabled
wlsxSignStaAsleap Yes Enabled
wlsxSignStaDeauthBcast Yes Enabled
wlsxSignStaNetstumbler Yes Enabled
wlsxSignStaNullProbeResp Yes Enabled
wlsxSignalAnomaly Yes Enabled
wlsxSignatureMatch Yes Enabled
wlsxSignatureMatchAP Yes Enabled
wlsxSignatureMatchSta Yes Enabled
wlsxStaAssociatedToUnsecureAP Yes Enabled
wlsxStaImpersonation Yes Enabled
wlsxStaInterferenceCleared Yes Enabled
wlsxStaInterferenceDetected Yes Enabled
wlsxStaPolicyViolation Yes Enabled
wlsxStaRepeatWEPIVViolation Yes Enabled
wlsxStaUnAssociatedFromUnsecureAP Yes Enabled
wlsxStaWeakWEPIVViolation Yes Enabled
wlsxStationAddedToBlackList Yes Enabled
wlsxStationRemovedFromBlackList Yes Enabled
wlsxSuspectUnsecureAPDetected Yes Enabled
wlsxSuspectUnsecureAPResolved Yes Enabled
wlsxSwitchIPChanged Yes Enabled
wlsxSwitchListEntryChanged Yes Enabled
wlsxSwitchRoleChange Yes Enabled
wlsxTKIPReplayAttack Yes Enabled
wlsxTarpitContainment Yes Enabled
wlsxTunnelDown Yes Enabled
wlsxTunnelUp Yes Enabled
wlsxUnsecureAPDetected Yes Enabled
wlsxUnsecureAPResolved Yes Enabled
wlsxUserAuthenticationFailed Yes Enabled
wlsxUserEntryAttributesChanged Yes Enabled
wlsxUserEntryAuthenticated Yes Enabled
wlsxUserEntryChanged Yes Enabled
wlsxUserEntryCreated Yes Enabled
wlsxUserEntryDeAuthenticated Yes Enabled
wlsxUserEntryDeleted Yes Enabled
wlsxValidClientMisassociation Yes Enabled
wlsxValidClientNotUsingEncryption Yes Enabled
wlsxValidSSIDViolation Yes Enabled
wlsxVlanEntryChanged Yes Enabled
wlsxVlanInterfaceEntryChanged Yes Enabled
wlsxVlanLinkDown Yes Enabled
wlsxVlanLinkUp Yes Enabled
wlsxVoiceCdrBufferThresholdReached Yes Enabled
wlsxVoiceClientLocationUpdate Yes Enabled
wlsxVrrpStateChange Yes Enabled
wlsxWEPMisconfiguration Yes Enabled
wlsxWPAMisconfiguration Yes Enabled
wlsxWarmStart Yes Enabled
wlsxWeakWEPIVViolation Yes Enabled
wlsxWindowsBridgeDetected Yes Enabled
wlsxWindowsBridgeDetectedAP Yes Enabled
wlsxWindowsBridgeDetectedSta Yes Enabled
wlsxWirelessBridge Yes Enabled
(config) #snmp-server trap disable wlsxWirelessBridge
(config) #snmp-server trap disable coldStart
(config) #show snmp trap-list
SNMP TRAP LIST
coldStart Yes Disabled
linkUp Yes Enabled
wlsxWirelessBridge Yes Disabled
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Thank you for that explanation.
Best Regards
