SNMP traps
Hi. Did read http://airheads.arubanetworks.com/vBulletin/showthread.php?t=700&highlight=snmp+traps but there was no reply.
Now, with actual 3.4 OS, can we now define anywhere which traps must be sent and which not ? Any public document ?
Thanks very much, regards
Alex
Alcatel-Lucent Enterprise Italy
Frequent Contributor II
Problem monitoring AP with SNMP with Solarwinds
When i change the Aruba OS from 3.3.X to 3.4.X we lost (by aruba redesign) the visibility of APs from our SNMP monitoring PC (Solarwinds).
I know that new version needs to askt to the controller not to the APs (and that´s cool and logic) but I don´t see any example how to do it in the User guide of this version.
I have Orion 9.5 and they say that support Aruba.
I see some errs of snmp that is concerning me like:
|snmp| An internal system error has occurred at file trans.c function SendToTransport line 187 error attempt to send to unknown transport type .
May be i did a mistake so:
How can I get that visibility again?
What do i need to config in the controller?
Regards.
Orion 9.5 Support
Regards.
Homero,
Aruba currently only supports polling and sending SNMP traps from the controller to a network management system; not the APs themselves. Solarwinds offers this solution here: http://thwack.com/forums/p/16365/67511.aspx to get proper visibility into Aruba devices.
I hope that helps.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Where SNMP Traps will be sent
Alex
At this time, all traps that are enabled will be sent to the SNMP trap host (s) defined on the SNMP configuration page on the Aruba controller. For traps to be sent, you must have a matching SNMP read string on the controller for the snmp trap host command that you configure.
