SNMPWALK Errors out
Aruba Controller:3600
AP:105
AM:93
Software: ArubaOS 5.0.2.1
snmpwalk -c publicsnmp -v2c aruba-master .
SNMPv2-SMI::enterprises.14823.2.2.1.4.1.3.1.2.0.240 = Counter32: 2
SNMPv2-SMI::enterprises.14823.2.2.1.4.1.3.1.2.0.1 = Counter32: 0
Error: OID not increasing: SNMPv2-SMI::enterprises.14823.2.2.1.4.1.3.1.2.0.240
>= SNMPv2-SMI::enterprises.14823.2.2.1.4.1.3.1.2.0.1
If I alter the SNMPWALK like so, I get put into a never ending loop that generates 150MB text file after a few minutes. :)
snmpwalk -Cc -c publicsnmp -v2c aruba-master .
repeated entries:
SNMPv2-SMI::enterprises.14823.2.2.1.4.1.3.1.2.0.120 = Counter32: 0
SNMPv2-SMI::enterprises.14823.2.2.1.4.1.3.1.2.0.5 = Counter32: 6
SNMPv2-SMI::enterprises.14823.2.2.1.4.1.3.1.2.0.15 = Counter32: 0
SNMPv2-SMI::enterprises.14823.2.2.1.4.1.3.1.2.0.30 = Counter32: 0
SNMPv2-SMI::enterprises.14823.2.2.1.4.1.3.1.2.0.60 = Counter32: 0
Is there a release where this has been fixed?
Re: SNMPWALK Errors out
Thanks for pointing that out. I'm able to reproduce it too. I can't find an existing bug, so I created bug 51443.
To track the status of the bug, you can open a support case.
Fixed in 5.0.3 and 6.1
This has been fixed in AOS 5.0.3.0 and will also be fixed in 6.1.
I upgraded to no avail. I logged another bug and engineering has reported back that there -WILL- be a patch released for 5.0 but it has not been released as of yet.
