AirWave and Network Management
Aruba
Sending Aruba SNMP traps to NMS system
I would like to be able to clear a load of old APdown traps from out nms systems using some sort of script on AMP.
I can easily send the 'wlsxAccessPointIsUp' trap from the command line using the command,
but how can I specify the trap objects, apLocation, apIpAddress, after the above command so that the down trap is cleared from out nms system.
ACCP, ACMP, ACMX #294
mclarke@arubanetworks.com
