AirWave and Network Management
Uploading CSV file of switches to scan
I want to add all of my switches (about 1000) to AMP for wired-side rouge scanning. How can I add them using a CSV (or other) file? It's not practical to add them all via Device Setup -> Discover.
Aruba
.csv upload from Deivce Setup -> Add page
There's a wizard for uploading them from a .csv on the AWMS's Device Setup -> Add page.
In our 6.4 release (eta early Nov) we are going to support scanning to add some models of Cisco switches.
Re: Uploading CSV file of switches to scan
Ok, but those devices don't go into Device Setup -> Discover to be able to configure them for wireline scanning. What am I not getting here? Documentation is at best confusing on this.
Hmmm, looks like AMP automatically scans those switches because I just got an email report on the scan results. Am I right here? If so, how often is it doing the scan of all the switches?
Aruba
Poll period is configurable
For each Group in AWMS, you get to configure how often we poll routers/switches for arp and bridge forwarding data.
Thanks Dan...I found those settings in the "Basic" tab.
