AirWave and Network Management
Super Contributor I
Who is using Airwave with Aruba 3.3.2.x
I'd like to get an idea for what other customers are utilizing Airwave to monitor/manager their controllers. We previously had MMS and are slowly migrating over to Airwave.
Ryan Holland
Network Engineer, Wireless ACMX
CIO - Infrastructure
The Ohio State University
320 W 8th Ave
Columbus, OH 43201
614-292-9906 holland.112@osu.edu
Ryan Holland, ACDX #1 ACMX #1
Re: Who is using Airwave with Aruba 3.3.2.x
Ryan,
We are using AMP 6.2.1 with Aruba 3.3.2.10. We had some problems with reporting and Airwave support spent a day applying some patches. All runs hunky-dory now though.
We run AMP in monitor-only mode at this time.
I am
I'm running AMP 6.2.2 with controllers on 3.3.2.8, monitor only, no WMS offload. AMP needs work, but it's getting there.
Super Contributor I
What sort of problems with reporting? Are you getting any traps from the controllers showing up in AMP?
Ryan - I get almost no traps from the controllers in AMP. We're trying to figure out if it's the controllers not sending the traps or if it's AMP.
Super Contributor I
Same symptoms here. We have all the supported traps enabled but never see anything on AMP. :-/
Getting Traps Sent
To get traps sent, you need to have a SNMP read community match your trap community. For example, you need the following for traps to be sent:
config t
snmp-server community airwave
snmp-server host 172.16.8.24 version 2c airwave udp-port 162
Colin Joseph
Aruba Customer Engineering
Thanks Colin. Yeah, all that's configured, but IDS traps aren't even generated on the controller. You see the IDS events on the controller web GUI (no WMS offload to AMP), but no traps in the queue.
I have a ticket open with Airwave and they're working with someone at Aruba to track down the issue. It actually doesn't appear to have anything to do with Airwave since the controller isn't generating the trap in the first place. It may end up being a bug.
FYI, I recently upgraded to 3.3.2.13 as well. Not for this issue, but to correct another one.
Regular Contributor I
AWMS currently processes IDS traps and traps related to 802.1x user authentication problems. We'll be adding support for more trap processing in future releases. The rest of the data AWMS uses is currently collected by periodically polling the controllers using SNMP.
Amp 6.2.3
We've got AMP 6.2.3 watching about 700 controllers (soon to be around 1400 controllers) all running 3.3.2.5 in Monitor only mode. We're actually hoping that once we've got all the controllers in AMP, we'll be able to use to upgrade them to something a little more recent. So far, AMP is making my life a little easier, since we didn't really have any central place to manage or monitor the controllers (never mind 3,500+ APs), but it does still have a long way to go.
