Aruba WLANs 101 and design fundamentals
Community Manager
Community Manager
Aruba WLANs 101 and design fundamentals - Although Aruba makes it easy to choose the best WLAN architecture to fit your IT and business needs, it's vital to sort through some critical pre-deployment issues before you get started. Join us to review the latest product and architectural options from Aruba as well as validated WLAN design best practices. This session includes in-depth coverage of Aruba Instant and Aruba Mobility Controllers.
 "Good basic view of the architecture types. I like the time spent making sure to show distinctions between controller and iAP setups"
Return to all breakouts.
 Aruba WLANs 101 and design fundamentals small.pdf (6,832 KB)
Version history
Revision #:
6 of 6
Last update:
‎09-15-2015 11:51 AM
Updated by:
Contributors
