Airheads Conference Vegas 2015
Super Contributor II
Breakout - Aruba WLANs 101 and design fundamentals
Aruba WLANs 101 and design fundamentals - Although Aruba makes it easy to choose the best WLAN architecture to fit your IT and business needs, it's vital to sort through some critical pre-deployment issues before you get started. Join us to review the latest product and architectural options from Aruba as well as validated WLAN design best practices. This session includes in-depth coverage of Aruba Instant and Aruba Mobility Controllers.
 "Good basic view of the architecture types. I like the time spent making sure to show distinctions between controller and iAP setups"
Return to all breakouts.
Sean Rynearson
Re: Breakout - Aruba WLANs 101 and design fundamentals
Is there a session breakout schedule available?
Basically which sessions are avialble on which days to help plan our time?
We will soon
Sean Rynearson
