Airheads Conference Vegas 2015
MVP
Breakout - The Aruba Tech Support Top 10: WLAN design, configuration and troubleshooting tips
The Aruba Tech Support Top 10: WLAN design, configuration and troubleshooting tips - This session gives you the latest best practices about deploying and managing an Aruba access network. Key members of Aruba’s technical support engineering team will talk about ArubaOS software releases, remote access point firmware-upgrade caveats, diagnostics to rectify connectivity and performance issues, and other best practices you can set in motion within the Aruba infrastructure.
Return to all breakouts.
Sean Rynearson
