Counter Mode with Cipher Block Chaining Message Authentication Code Protocol - CCMP
Community Administrator
CCMP - The default encryption method defined under the 802.11i amendment. This method uses AES encryption.
Distributed Coordination Function (DCF) "CSMA/CA is provided by this, which is the mandatory access method of the 802.11 standard"
Version history
Revision #:
1 of 1
Last update:
‎12-29-2014 08:11 AM
Updated by:
Contributors
