Americas Airheads Conference 2012
Retired Employee
Video: Influence Sessions: High-Density Wireless LAN
Sean Rynearson introduces the first Tech Field Day Roundtable discussion at Aruba Airheads 2012 in Las Vegas. After introductions, the panel discusses the implications and technical requirements for high-density wireless LANs, wireless networks for high capacity venues where high noise floors and rogue access points are present.
Run Time: 00:13:26
