Americas Airheads Conference 2012
Retired Employee
Video: Influence Sessions: Large-Scale WLAN Management
Chris Lyttle introduces the third Tech Field Day Roundtable discussion at Aruba Airheads 2012 in Las Vegas. The panel discusses large-scale WLAN management, of multiple sites, worldwide deployments or redundant networks.
Run Time: 00:09:47
