401 Fobidden on Guest Self-Regi
Has anyone come across '401 Forbidden' when trying to open the Guest Registration page from a WiFi client?
Thinking this may be from a NAT or IPSEC source mismatch perhaps?
Re: 401 Fobidden on Guest Self-Regi
You should first look at Customize> Web Logins and test that page to see if it comes up properly.
Colin Joseph
Aruba Customer Engineering
