Amgopod HA
We are currently experiecing issue when configuring the Cluster option with the Amigopod software. Has anyone configured this option aand got it working. When we initialize the cluster when are presented with a Radius error.
Re: Amgopod HA
What is the exact error you are getting? If you do not have the High Availability Tech Note get it from support.
It does require your systems fully up to date. Check your plugin updates, as well as the OS-level updates under Admin > OS Updates > Manual OS Updates: Review Logs.
error message
error after initialisation "Internal error: Could not initialize RADIUS Services replication " and the HA won't form.
Re: Amgopod HA
Checking for updates...
Loaded plugins: fastestmirror
Determining fastest mirrors
amigopod
primary.
http://www.amigopod.com/amigopod-os/1.2/updates/x86_64/repodata/primary.xml.gz: Metadata file does not match checksum
Trying other mirror.
primary.
Error: failure: repodata/primary.xml.gz from amigopod: No more mirrors to try.
Any ideas?
Also re: the High Availability Tech Note, do you mean chapter 10 in the Deployment Guide? If not could you email me the doc you specified?
