Amigopod
Super Contributor I
Aruba OS integration with Amigopod
All,
I am currently running a demo of Amigopod and am looking to do some further testing next month. I would like to demo using the Amigopod guest provisioning and captive portal technology in lieu of the native ArubaOS solution.
Has anyone integrated the product into their Aruba deployment? If so, what are your experiences so far?
Thanks!
-Mike
Re: Aruba OS integration with Amigopod
We are testing this right now and I have been very happy so far.
There is a cheat sheet that your rep can get you to get you up an running quickly.
We are going to be using this for self registration to our guest network.
John
Contributor I
where can i get the cheat sheet?
go to http://support.arubanetworks.com
Go to Documentation> Amigopod> Integration guides.
