Regular Contributor I
Custom Skins
I am having a really hard time trying to get titles centered after switching to custom skin 1 where I simply replaced the AmigoPod logo with a company logo.
I am no expert in HTML but I have had others look and it would apear that under the custom skin we can set some CSS styles but nothing we do seems to stick.
What I really want is to get all titles/headers to be fully left justified. Any suggestions. I have opened a TAC case but the turn around time on this one is taking a long time and we are scheduled to go live with this soon and at present the format does not look professional.
Re: Custom Skins
Hi Alan. I see your TAC case. The answer must have been lost in translation as the fix was sent up the chain last Wednesday.
Add the following to the CSS area:
<style type="text/css">
#tdTitle {
width: 100%;
</style>
Depending on your version, this may give an error about the '{'. If so, use the following:
{literal}
#tdTitle {
width: 100%;
</style>
{/literal}
Basically, the header and title are each cells of a table. A two cell table automatically gives each cell half by default. So we need to stretch the title, or squeeze the logo.
An alternative would have been:
#tdLogo {
width: 300px;
</style>
With the width set to a little more than whatever the image width is.
Worked!
Thank you so much I spent days on this. Finally it looks good.
