Amigopod
MC
Occasional Contributor I
Manual provisioning email notification
If we are going the route of doing manual provsioning of accounts via the AmigoPod, is there an easy method of sending an email with the credentials to the Sponsor?
Our current environment is going to be the local administrative assistant to the location will be enabled to provision out guest accounts. There doesn't appear to be any notifications sent to anyone when an account is created. We would like to be able to easily pass along the guest credentials to the sponsor to be handed off to the guest.
Re: Manual provisioning email notification
Any of the email receipt setup sections have a spot for a CC or BCC list. You can used fixed addresses and dynamic ones.
This will send emails to amigopod-guests@acme.com as well as whatever was typed into the sponsor_email field. Note that if you are using LDAP for operator logins, you can map the email attribute to our sponsor_email using the translation rules.
