Frequent Contributor II
Self Registration help
I have setup a Self Registration form on my Amigopog, but I'm a bit confused about the NAS login page. Do I specify my controller's ip address here or something else?
so far, I have it working as far as the client getting to the self-reg page, then after creating a login, gets to the login page, after entering the credentials I receive the message "Wi-fi can't verify the identify of "172.116.100.145". Would you like to continue anyway ?
If I choose continue, I go back to Self-Reg page
the IP address is my controllers mangement interface, which I have specified on my NAS login page.
thanks
Lee
Re: Self Registration help
Please go to support.arubanetworks.com. Go to documentation> Software User & Reference Guides> Amigopod> Integration Guides. Find the document for your WLAN infrastructure and follow those instructions step-by-step. Those guides really simplify the process.
