Amigopod
Contributor I
how to setup amigopod issue client cert?
Hi all,
I saw demo video from aruba which use amigopod to issue client certificate. But I'm no idea to start it. Have anyone know how to start it?
thanks in advance
Re: how to setup amigopod issue client cert?
To start the process, the WLAN that the client connects to is configured to redirect the client to a captive portal hosted on the Amigopod appliance. From there, the Amigopod can interact with the user, collect credentials, and push profiles and certificates to the end device.
Does that help?
Charlie Clemmer
Aruba Customer Engineering
Contributor I
Does that help?
Hi Clemmer,
thanks for your reply. Now I'm done with WLAN redirected to amigopod box then I can authentication by amigopod but I'd like to use amigopod issue client cert to end device after passed the authentication.
anyone have a document or screen capture to config amigopod issue client cert?
thanks in advance
Is your Amigopod appliance running 3.3?
Charlie Clemmer
Contributor I
My Amigopod running in version 3.3 on VMware.
