Aruba Apps
I need to replace 5 power supplies for ARUBA RAP2WG and I am unable to find a part number
Regular Contributor I
Re: I need to replace 5 power supplies for ARUBA RAP2WG and I am unable to find a part number
Voltage and watt wise, it looks like this should work:
AP-AC-UN 12V / 18W indoor Access Point AC power adapter. Universal, ships with 8 country-specific plug inserts
my only concern is that the actual plug shape might be different.
From the RAP2 data sheet:
Adapter (included):
- AC Input: 100-240V/0.3A
- DC Output: 12V/1A
Maximum Power Consumption: 6.5W
So this adapter should have the juice, the question is does it fit?
_ELiasz
ACDX, ACCP, CISSP, CWNA
