Aruba Apps
Occasional Contributor I
RAP-155 use same network wired name when configured more than 1 RAP
 I configured RAP-155 for remote Access, and I have the RAP around 4-5 devices
I assigned each RAP per 1 AP-Group.
I work fine for SSID Name , there is no issue about this
BUT when connected via wired , it use same name for all RAP.
How can I set diferent name for each wired network ?
Thank so much
Warinda
Re: RAP-155 use same network wired name when configured more than 1 RAP
Can you show us a screenshot?
please find the screenshot as attached file.
PS. all of AP-Group that use RAP-155 when connected via wired  they got same name "NSGT-PINTONG"
Thank you
Warinda
Is that the name of your internal domain ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
No, it is the SSID name for the first RAP-155 that we had configured before,
As we seperate each RAP to 1 AP-Group , but when connecting via wired it shows same name.
Are you using the same VLAN on wired and on that SSID ?
Thank you
Victor Fabian
Yes it is, I used same VLAN on wired and SSID but different VLAn for each AP-Group
NSGT-PINTONG -- VLAN 57
SDD-Rempote -- VLAN 59
Have you tried changing the name of that SSID?
And if it gets reflected on the wire side.
The information listed in the wire connection status is usually obtained from the DNS server
Thank you
Victor Fabian
Yes I did change, even I changed Whitelist from AP Group Remote-SDD to Remote-L2
the SSID showed  NSGT-L2Remote but wired connect still show NSGT-PINTONG.
I'm wondering why the wired connection used that name? and where it gets from?
** we use internal DNS from controller and no any that name from our DNS server
Internal DNS from the controller ?
The controller doesn't have DNS capabilities .
What are you using for DHCP ?
Thank you
Victor Fabian
