Aruba Apps
Occasional Contributor I
VisualRF Plan not starting
VisualRF Plan was working fine on my laptop when suddenly I could no longer start the application. No errors show up that might indicate the underlying issue.. the application just doesn't start when I click its icon.
My OS is Windows 8.1 and Google Chrome is my default browser.
Appreciate if you can help me solve this issue.
Re: VisualRF Plan not starting
Which version are you running? In the later versions it is browser/Java based. If you are running v8 and above try the following. This happens on a frequent basis to myself and the below worked for me previously when there was issues and there has been no changes to my system....
- Uninstall VisualRF
- install the latest JAVA version and adobe flash player.
- Delete temp %temp% folders and prefetch folder. Rebooted the PC.
- Re-install VisualRF
ACMA, ACMP, ACSA
If my post addresses your query, give kudos:)
Thank you so much zalion0.. it worked!
Glad to hear it! :D
ACMA, ACMP, ACSA
