Q: How to connect a managed controller to a MM?
ASE Link: Go to the solution
A: Summary
This solution shows how to initially configure a Managed Controller (MC) also known as a Managed Device (MD) and then deploy it in Mobility Master 8.0 domain model. The MC can take a variety of platforms. Most commonly it will be a hardware controller of different model types or it may be a VMC type. In this solution, we deploy a 7220 hardware controller as an example but this can be generalized to most controller types.
The is the second or companion piece to setting up a simple MM cluster configuration. The first or preceding solution is listed here:
Deploy a MM VMC to ESXi
Software Version(s) Required
A already configured Mobility Master 8.0 (MM) controller
Configuration Notes
Initial setup of the MM - MC requires coordinated configuration on both devices and is detailed in this solution.
The new MM model has a very different method of configuration after this setup. All configurations are pushed to the MC from the MM. Troubleshooting is still often done on the MC and MM depending on the specific issue.
Platform(s) Tested
Aruba 7220 controller running AOS 8.0
MM 8.0 Controller
Licenses
None
References
