Mobility Master Redundancy
How to configure 8.x Mobility Master redundancy?
ASE Link:  Go to the solution
This solution creates redundancy between two Mobility Masters to form an primary-standby Mobility Master pair.
  • MM - Mobility Master
  • MC - Mobility Controller
  • VRRP - Virtual Router Redundancy Protocol
  • VIP - Virtual IP Address
In this solution, we will configure the following:
  • VRRP: Having a VIP between the primary and standby MMs will ensure that Mobility Controllers (MC) can connect to the standby MM when the primary MM becomes unreachable.
  • Master redundancy: Ensures that any configuration changes applied on the primary MM are immediately synchronized with the standby MM.
  • Database synchronization: Ensures that the databases (e.g. license, WMS, AP, User, etc.) are synchronized between the two MMs.
Ensure that the primary and standby MMs are L2 separated.
Configuration notes
  • The entire configuration hierarchy is synced from the primary Mobility Master to the redundant Mobility Master, except any configurations under /mm/mynode.
  • Configurations common to both the primary and redundant Mobility Masters are placed under /mm node so that they can be synced to the redundant controller.
  • Configurations specific to individual Mobility Masters must be placed under /mm/mynode on the respective Mobility Master. For example, IP address and VRRP configurations are different for each device under Mobility Master and can be placed under the respective /mm/mynode for each device, while configurations for Mobility Master services can be placed under the /mm node.
  • All configuration changes at the /mm and /md level on the primary MM are propagated to the standby MM.
  • When redundancy is configured between two MMs, all available licenses are synchronized between the MMs. Licenses for each MM get aggregated.
  • When upgrading the MM pair, the upgrades need to be done individually on each MM (at the /mynode level).
platform(s) Tested
  • MMs running AOS
To learn more about MM redundancy, please refer to the following resource:
Version history
Revision #:
2 of 2
Last update:
‎12-08-2016 03:03 PM
Updated by:
Labels (1)
