ArubaOS and Controllers
650 controller with usb modem
I am trying to use a vodafone usb E220 cellular modem and i keep getting Error: Cellular chat error when i look at the state. the vodafone modem is based out of ireland and i have tried the following init and dial strings. What does the usb_type=option (2) mean?
usb_type=option (2) usb_init=AT+CGDCONT=1,'IP','internet' usb_dial=ATDT*99#
Re: 650 controller with usb modem
Is this for a remote AP or one connected to the controller USB port? If it is for the controller you can create a cellular profile to try to provision the unsupported modem. The option (2) you described above is for remote APs using a Option evdo modem.
