ArubaOS and Controllers
800/2400 AP LED Status
I'm sure in the past, I remember a command was available to see the status of the AP LEDs remotely on a controller.
Can anybody remind me what this is, or am I going mad? Does it still work on 3.3 and 3.4?
Thanks.
J.
LED Commands
Thanks.
J.
Used to work. Removed lately in 3.3 and 3.4
Re: 800/2400 AP LED Status
Would "show ap debug system-status ap-name" have the information that you are looking for?
# show ap debug system-status ap-name xyz
Interface counters
Interface Rx_pkts Rx_errors Rx drops Tx_pkts Tx_errors Tx_drops Resets
wifi0 0 0 0 0 180666 0 0
wifi1 0 0 0 0 1369490 0 0
stats for wifi0
longslot=0 nonerp=0 non_ht=5 ht20=0 unknown_bssid=0 mgmt_to_stm=0 eapol_to_stm=0 eapol_decap_fail=0 ni_allocs=333 ni_frees=324 auth_throtl=0 auth_q_ovfls=0 assoc_throtl=0 num_nodes=7 auth_wndw=1 tx_pkts_to_am=16208216 bcn_nul_events=0 bcn_nul_bits=0x0 kcache=0 prot_mode=1 use_prot=0 htprot=0 ht_prot_sm=3 short_pre=1 config_deferred=3 config_waiting=0 config_waits=0
stats for wifi1
longslot=0 nonerp=0 non_ht=0 ht20=0 unknown_bssid=0 mgmt_to_stm=0 eapol_to_stm=0 eapol_decap_fail=0 ni_allocs=8809 ni_frees=8796 auth_throtl=0 auth_q_ovfls=0 assoc_throtl=0 num_nodes=2 auth_wndw=1 tx_pkts_to_am=8275845 bcn_nul_events=0 bcn_nul_bits=0x0 kcache=0 prot_mode=1 use_prot=1 htprot=0 ht_prot_sm=1 short_pre=1 config_deferred=1824 config_waiting=0 config_waits=0
AP Uptime
35 days 17 hours 43 mins 38 secs
Ethernet Duplex/Speed Settings
Autoneg Speed (Mbps) Duplex Iface
on 1000 Full eth0
on 10 Half eth1
-Eva
show ap-leds
Thanks.
J.
The show ap-leds command would show the status of the LEDs on the front of the 800 and 2400 controllers. The leds would light up if an AP was directly plugged into the controller or there was a rogue AP on the link. Since the majority of users are not physically in the same room as the controller, these lights are not particularly useful. The "show poe" command http://airheads.arubanetworks.com/vBulletin/showthread.php?t=710 will show you if something using POE is plugged into a physical port is being powered by controller. The "show ap database long" command will show you what port and slot an AP's traffic is coming into the controller on:
(Aruba800-4) #show ap database long
AP Database
Name Group AP Type IP Address Status Flags Switch IP Wired MAC Address Serial # Slot/Port FQLN Outer IP
Mesh-Point default 70 1.1.1.253 Up 1d:13h:30m:9s M 192.168.15.3 00:0b:86:c5:4c:c8 A71074028 1/1 N/A N/A
MeshPortal default 125 1.1.1.254 Up 1d:13h:14m:11s M 192.168.15.3 00:1a:1e:c0:24:0a A82005113 1/1 N/A N/A
Survey-125 remote 125 172.16.93.3 Down R 192.168.15.3 00:1a:1e:c0:24:12 A83005117 N/A 0.0.0.192
Flags: U = Unprovisioned; N = Duplicate name; G = No such group; L = Unlicensed
R = Remote AP; I = Inactive; X = Maintenance Mode; P = PPPoE AP; B = Built-in AP
S = RFprotect Sensor; d = Disconnected Sensor; H = Using 802.11n license
M = Mesh node; Y = Mesh Recovery
Total APs:3
