ArubaOS and Controllers
802.1x authentication with FreeRadius
Redhat is FreeRadius in my network. i configure the controller3200 that is Aruba OS version 6.1.2.2 to authentication with FreeRadius
I add radius client in client.conf in FreeRadius already after i add ip address of FreeRadius and secret in the controller
I use Diagnostics for testing and i see that PAP is authentication successful but the MSCHAPv2 is authentication failed
i understand that Redhat is not support MSCHAPv2 please help me...
Re: 802.1x authentication with FreeRadius
If the backend of the RADIUS infrastructure does not support MSCHAP, then you'll need to use GTC to send the password non-hashed to the RADIUS backend. Apple supports this natively, but Windows machines require a 3rd party plugin or supplicant.
Charlie Clemmer
Aruba Customer Engineering
MSCHAPv2 is more dependent on what backend database you integrate with; http://deployingradius.com/documents/protocols/compatibility.html
If you integrate Freeradius with active directory, you can do this. there are more pages on the deploying radius website that detail how to do this.
If you would like, you can download a special Windows version of Freeradius, already setup for Mschapv2. You can use some of the parameters from there for your Linux Setup:
url: https://iris.arubanetworks.com
code: 9e04ef1bec5971924cef9dc0b2631fba
Thanks very much
