ArubaOS and Controllers
Contributor I
A200 - Max. size for the CompactFlash
Hello.
I have some problems with an Aruba A200 and have to change the compactflash. Currently, the memory size is 256 MB.
What is the maximum size this device is able to manage? Do you recommend to increase this size?
Thanks.
Re: A200 - Max. size for the CompactFlash
The compact flash is not a user-serviceable piece of equipment. If you are having problems with the hardware, please contact support and get their advice on what the root cause of your problem is.
