ArubaOS and Controllers
AOS 5.0.1.0 Module STM is busy
Hi all,
When I'm trying to do some commands on ssh console it just freeze and pop up the message
(ARController) #show ap database status down
Module STM is busy. Please try later
Would you please advice what is it and how to sort it out. Also, it seems that when it freeze, our AP125 lost connection with the controller as well
It's 6000 controllers using AOS 5.0.1.0.
Thank you,
Peter
Re: AOS 5.0.1.0 Module STM is busy
There are a number of reasons why this happens. The best thing to do, if you do not want to open a TAC case is to upgrade to the latest 5.x code.
