ArubaOS and Controllers
AOS 6.1.2.2 does not like AP names with spaces
Hi All,
Just a quick heads up. You will not be able to reprovision APs with spaces in their names from the web console with a controller on version 6.1.2.2. See below...
I replaced a customers 800 controller with a 3400 today and upgraded the code to 6.1.2.2. Not sure who installed the previous controller but they provisioned the APs with spaces in the name. All the APs came up but I was unable to reprovision them (needed to move them to different floors on the plans). When attempting to provision on AP with a space in the name the provisioning page went blank. APs with no spaces in their names could be provisioned fine.
I cleared by browser cache and tried a different browser to no avail.
I spoke to Aruba TAC who told me this is a known issue. Here's the fix..
On the cli do the following:
#conf t
#provision-ap
#ap-name
#reprovision ap-name ""
The AP will come back up in the default AP group with the new name you stated. Just reprovision from the web console into the correct group.
Cheers
James
*If there's an easier way to do this please let me know.
Cheers
James
Re: AOS 6.1.2.2 does not like AP names with spaces
Thank you.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Has this been fixed in 6.1.2.3? Didn't see any mention of it in the release notes.
Contributor II
We came across the same issue but corrected it slightly differently. We used:
#ap-rename ""
It did the same thing though. Also, make sure that you use the quotations around the ap name that has spaces in it. If you don't the command will fail.
Thanks for the suggestion, but I still can't get it to work. Get the 'Invalid Input detected' error. The AP is up and running on this controller.
(Aruba-1490) (config) #ap-rename 00:1a:1e:XX:XX:XX 1540-East
% Invalid input detected at '^' marker.
(Aruba-1490) (config) #ap-rename "1540 - East" 1540-East
Thoughts? The controller is running 6.1.2.3.
ap-rename ap-name "name of ap" new-name-of-ap
This did the trick. Thanks!
