ArubaOS and Controllers
Occasional Contributor I
AOS-W 5.0.3.2 clients are not filtered properly using essid
I have an Alcatel 6000 controller with AOS-W 5.0.3.2 on it. When I try to use WLAN section on the monitoring page in Web UI, and try to list clients. It does not return any or it returns an incorrect list. Is Anybody having such problem? By the way, I installed and tried 6.0.1.2 and 6.0.1.0 respectively before 5.0.3.2, and controller had reloads with datapath and watchdog timeouts reasons. We have 400+ AP61 with an M3 card, using captive portal both with wired and wireless profiles. If it is not the case with the software I guess I am going to reload sometime.
Re: AOS-W 5.0.3.2 clients are not filtered properly using essid
For the display issue, I would clear my browser cache.
For the datapath reboots, please contact support ASAP.
oh my bad I forgot the include, it is the same with console command.
(AWAC) #show user-table essid 3_Kuzey_Yurt
Users
IP MAC Name Role Age(d:h:m) Auth VPN link AP name Roaming Essid/Bssid/Phy Profile Forward mode
192.168.0.1 00:24:2c:0a:09:e4 authenticated 00:09:56 00:24:6c:c1:79:de Wireless Boun-Wlan-N/00:24:6c:97:9d:e0/g YolGecenHan tunnel
192.168.1.33 00:22:fa:72:09:00 authenticated 00:02:53 N/A Wireless Boun-Wlan-N/00:24:6c:97:88:60/g YolGecenHan tunnel
193.140.192.20 00:1f:3b:9f:20:1b cap-guest-logon 01:06:23 N/A Wireless 4_Kuzey_Yurt/00:24:6c:f4:06:f0/g cap-aaa-profile tunnel
192.168.1.1 00:1c:a8:19:27:2c 001ca819272c cap-guest-logon 02:03:46 tunnel 1 Wired cap-aaa-profile tunnel
192.168.1.2 00:25:d3:01:56:b1 authenticated 00:05:57 N/A Wireless Boun-Wlan-S/00:24:6c:96:f3:d0/g YolGecenHan tunnel
193.140.192.50 00:1f:3b:9f:20:1b cap-guest-logon 01:06:23 N/A Wireless 4_Kuzey_Yurt/00:24:6c:f4:06:f0/g cap-aaa-profile tunnel
192.168.1.103 1c:65:9d:3e:71:78 1c659d3e7178 cap-guest-logon 02:01:31 tunnel 1 Wired cap-aaa-profile tunnel
192.168.2.2 00:23:4d:e3:fe:b2 authenticated 01:01:43 N/A Wireless Boun-Wlan-N/00:24:6c:97:9d:e0/g YolGecenHan tunnel
192.168.2.3 00:1a:73:3b:18:39 authenticated 00:04:19 N/A Wireless boun_guest/00:24:6c:97:8f:50/g YolGecenHan tunnel
192.168.164.134 c4:46:19:7a:e6:15 authenticated 00:00:01 00:24:6c:c1:6f:7a Wireless Kilyos_Guney_yurt/00:24:6c:96:f7:a0/g YolGecenHan tunnel
192.168.164.147 00:0d:f0:39:30:85 authenticated 00:00:30 00:24:6c:c1:6f:7a Wireless Kilyos_Guney_yurt/00:24:6c:96:f7:a0/g YolGecenHan tunnel
192.168.100.202 00:22:fa:2e:83:b2 seyhan.aktas authenticated 00:07:35 Web 00:24:6c:c1:70:3c Wireless 1_Kiz_Yurdu/00:24:6c:97:03:c0/g cap-aaa-profile tunnel
192.168.164.40 f0:7b:cb:47:01:be authenticated 00:05:01 00:24:6c:c1:78:e1 Wireless Kilyos_Guney_yurt/00:24:6c:97:8e:10/g YolGecenHan tunnel
192.168.100.40 70:1a:04:da:3d:b9 yesim.olcer authenticated 00:00:43 Web 00:24:6c:c1:6f:e9 Wireless 1_Kiz_Yurdu/00:24:6c:96:fe:90/g cap-aaa-profile tunnel
192.168.100.41 00:22:5f:04:3f:d4 ece.mendi authenticated 00:06:15 Web 00:24:6c:c1:6f:e9 Wireless 1_Kiz_Yurdu/00:24:6c:96:fe:90/g cap-aaa-profile tunnel
192.168.100.43 00:15:af:ce:50:68 duygu.koyden authenticated 00:02:54 Web 00:24:6c:c1:7a:20 Wireless 1_Kiz_Yurdu/00:24:6c:97:a2:00/g cap-aaa-profile tunnel
192.168.164.44 e0:91:53:1c:46:06 authenticated 00:04:55 00:24:6c:c1:79:44 Wireless Kilyos_Guney_yurt/00:24:6c:97:94:40/g YolGecenHan tunnel
192.168.164.45 70:1a:04:7c:4b:21 authenticated 00:04:55 00:24:6c:c1:7a:40 Wireless Kilyos_Guney_yurt/00:24:6c:97:a4:00/g YolGecenHan tunnel
192.168.100.46 00:24:2b:9a:6a:f4 dilek.calik authenticated 00:01:17 Web 00:24:6c:c1:7a:26 Wireless 1_Kiz_Yurdu/00:24:6c:97:a2:60/g cap-aaa-profile tunnel
Is that your only controller in your network? What did you upgrade from, initially?
yes it is the only one. we upgraded because we purchased pefng licenses, which were not compatible with 3.x.
Do you have the backup flash from before you upgraded that you can go back to? If not, do a "backup flash" right now.
After that do a wms reinit-db and then reboot, because the database structure is different and that might be causing your issue.
sorry for the late response, I wms re-init ed and rebooted. It did not solved the issue.
You need to open a support case, because something else is going on...
thanks, I will do as soon as possible.
