Occasional Contributor I
AP-175 Keep Reboot
we just having problem with the configuration between AP-175 and Aruba Controller 3200. the first install everything running good but then when we tried install at site suddenly the AP-175 keep rebooting after successfully registered.
see attached the configuration and logs from the AP. please advise asap and need your help
