AP and RAP Licensing
I have a prospect that requires RAP´s over 125´s. Does he needs to buy the AP licenses plus RAP´s Licenses or just the RAP licenses on M3?. Thanks in advance
RAP Licenses
Only RAP licenses are required for access points that are in Remote AP mode (ipsec). AP, or Campus licenses are required for APs that contact the controller using GRE. When you say RAPs over 125s, do you mean APs that use AP 125s to tunnel traffic?
Colin Joseph
Aruba Customer Engineering
Re: AP and RAP Licensing
You just need to add the RAP liccense, so you dont need to add the AP lic. So in general terms you buy one or the other not the two for the same device.
