ArubaOS and Controllers
Occasional Contributor I
AP at plant assign head office IP
I'm new with Aruba,
We have Aruba controller at Head office that has IP XX.XX.32.XXX .
And we have AP at branch that has IP XX.XX.33.XXX.
At the plant has own DHCP server ,
My problem is When Client at plant connect it get IP xx.xx.32.xxx that is Head office IP instead of XX.XX.33.XXX Plant IP.
Please advise how can i do to get the correct ip.
thabks
Re: AP at plant assign head office IP
What you need to do, is first turn on CPSEC or control plane security and auto cert provisioning. This is located under configuration> Network> Controller> Control Plane Security
.. and click on "apply" in the lower right-hand corner. Please do this in the off-hours, because access points will reboot, and take about 7 to 8 minutes to come back up.
Next, you want to change the forwarding mode in the Virtual AP profile for those clients to "Bridged". Go to configuration> Wireless > AP configuration. Click edit to edit the AP group that you want to change. Expand Wireless Lan> Expand virtual AP and click on the Virtual AP that you want to change. Change the Forward Mode to bridge, to bridge that traffic, instead of tunneling it:
..and then click on apply.
Thanks cjoseph for your replying. For vlan number can i use Vlan 1?
Vlan number is vlan at Plant site, right?
The VLAN number does not matter when you are bridging, unless the access point is connected to a switch trunk port.
Hi Cjoseph
How about the controller ? need to connected to trunk port or not?
My current problem is I can ping to Access point at plant but it does not show on Controller
but if i set trunk port on Aaccess point connected i cannot ping to it.
* I already enable CPSEC , forward mode is Bridge.
Could you please advise me the steps to check the problem....
Thanks very much
When did you switch CPsec on? Did you turn on Auto Cert provisioning, as well? Do a "show ap database" on the controller so we can see what state they are in. The Aruba controller does not have to be on a trunk.
Hi cjoseph
Now i can see that AP , but Client cannot connect to that AP.
* I use radius server to authentication.
Thanks very much for your kindly help.
Turn on client debugging and look at the output:
config t
logging level debug user
show log user 50
