ArubaOS and Controllers
AP not registering
I am setting up a 3200 controller and reset it to defaults yesterday. I have one AP-105 that was registered to the controller before I reset it. What do I have to do to get the AP to register with the controller again? I have DHCP configured on vlan 1 using a different IP network than I used before. Now the AP has unapproved-factory-cert under its state.
What do I need to do to resolve this?
Thank you,
Aruba
Re: AP not registering
Certificates are only used if you are leveraging control plane security (CPSEC) for the Campus APs. You can disable this if you want to keep things simple (KIS) and that should allow the AP to fully register easily.
Ouside of that, you can cycle the AP (drop down menu) on the Campus_AP_Whitelist to change its status as well.
