ArubaOS and Controllers
MVP
AP packet capture failing?
I've been trying to get a packet capture from an AP via Monitoring > all AP's and then selecting an AP here and clicking Packet Capture.
After selecting the right ssid I've added a stream with target ip being my pc's wired interface and then starting this stream.
In Wireshark (latest version: 1.6.0) I've set up aruba_erm (under preferences) to look at port 5555 and am sniffing my wired interface.
All firewalls and virusscanners have been disabled yet I do not get ANY aruba_erm traffic.
I've tried this with controllers running versions 6.0.1.2 and 6.1.1.0 without success.
Has anyone else encountered this?
EDIT: found the issue. The AP is sending the capture data so its role (ap-role) needs to allow for traffic towards port tcp 5555. As soon as I edited this role my capture works.
Koen (ACMX #351 | ACDX #547 | ACCP)
Re: AP packet capture failing?
Thank you very much.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
