ArubaOS and Controllers
AP60 wont connect by dhcp or static
I pulled a new AP60 from storage to setup and install and it is malfunctioning: will not acquire ip from dhcp and reboots. When I setenv static ip etc the 2400 controller does not identify the AP60. The AP60 had default factory config and I already performed: purge, save, boot. I also reviewed show log system 50 and show datapath session table and did not see anything relevant.
Any suggestions or should I move for RMA? TIA.
SOE LOG:
APBoot 1.5.5 (build taylor@harpua-ENG.0000)
Built: 2006-02-24 18:29:36 (with gcc 3.3.1)
CPU: AR2313 MIPS-32 at 180 MHz: 16 kB I-Cache 16 kB D-Cache
Board: Merlot, Local Bus at 90 MHz
DRAM: 32 MB
POST: mem 0 mem 1 mem 2 mem 3 passed
FLASH: 4 MB
Net: en0 lo0
Hit to stop autoboot: 2
DRAM: 32 MB
FLASH: 4 MB
Net: en0 lo0
Hit to stop autoboot: 2 0
apboot>
apboot> printenv
boardname=Merlot
autostart=yes
baudrate=9600
bootdelay=2
bootcmd=boot ap
bootfile=mips.ari
servername=aruba-master
ethaddr=00:1a:1e:c4:dc:61
Environment size: 141/8186 bytes
apboot>
apboot> purge
Erasing....
Programming....
Verifying....
apboot>
apboot> save
Erasing....
Programming....
Verifying....
apboot>
apboot> boot
Loading FLASH image @ 0xbfc40000... not present
Loading FLASH image @ 0xbfc80000...
Verifying checksum...
Booting image...
Aruba Networks
ArubaOS Version 3.4.2.0 (build 23093 / label #23093)
Built by p4build@stan on 2009-12-18 at 10:13:27 PST (gcc version 3.4.3)
BOARD - Merlot
CPU frequency 180.00 MHz
Using 90.000 MHz high precision timer. cycles_per_jiffy=180000
Memory: 26652k/32768k available (1986k kernel code, 6100k reserved, 429k data, 2212k init, 0k highmem)
available.
detected lzma initramfs
initramfs: LZMA lc=3,lp=0,pb=2,dictSize=8388608,origSize=11518976
LZMA initramfs by Ming-Ching Tiew ................................................................................................................................................................................
wdt: registered with refresh
RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
physmap flash device: 400000 at 1fc00000
AMD Flash AM29LV320D (Top) (Unknown locking)
phys_mapped_flash: Found 1 x16 devices at 0x0 in 8-bit bank
Amd/Fujitsu Extended Query Table at 0x0040
number of CFI chips: 1
Parsing the partition info
Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
Starting Kernel DES KAT ...Completed Kernel DES KAT
Starting Kernel AES KAT ...Completed Kernel AES KAT
bond0: Atheros AR2313: 00:1a:1e:c4:dc:61, irq 4
AP xml model 1, num_radios 1 (jiffies 7897)
init_asap_mod: installation:0
radio 0: band 2 ant 1 max_ssid 16
asap_gre_init: ADDED GRE protocol c00a3908
ath_hal: module license 'Proprietary' taints kernel.
ath_hal: 0.9.17.1 (AR5212, AR5312, RF5111, RF5112, RF2413, RF5413, RF2316, RF2317)
ath_rate_atheros: Version 2.0.1
Copyright (c) 2001-2004 Atheros Communications, Inc, All Rights Reserved
ath_dfs: Version 2.0.0
Copyright (c) 2005-2006 Atheros Communications, Inc. All Rights Reserved
ath_ahb: 0.9.4.5 (Atheros/multi-bss)
devid=0x58
AR2313_REV8
wifi0: Base BSSID 00:1a:1e:cd:c6:10, 16 available BSSID(s)
edev->dev_addr=00:1a:1e:c4:dc:61
wifi0: AP type AP-60, radio 0, max_bssids 16
wifi0: Atheros 2313 WiSoC: mem=0xb8500000, irq=5
net.aruba_asap.br_init = 1
Getting an IP address...
DHCP timed out. Rebooting
killall: nanny: no process killed
killall: sapd: no process killed
The sys
Sending SIGKILL to all processes.
Please stand by while rebooting the system.
<0>Restarting system.
Re: AP60 wont connect by dhcp or static
Instead of typing purge at the apboot prompt, type "dhcp" and see what the result is. You may have to type dhcp a couple times. If you can, plug a regular client into the same port and see if it can get DHCP. If that does not work, please contact TAC.
I forgot to add earlier that I already performed several 'dhcp' commands with no results. Other APs on the same port get dhcp no problem.
Thanks.
Thanks.
You should contact TAC at this point.
