ArubaOS and Controllers
AP61 and Bridging/Split Tunneling
None of my APs configured as campus APs will broadcast the SSID I have configured for split tunneling (when dropped in the appropriate AP group). RAP2s configured as remote APs will work, as well as AP105s. I'm assuming the AP61 may not be able to function as a remote AP. If so, was there ever a split tunneling scenario using the AP61? May I have a sample config? Aruba OS 6.1.0
Re: AP61 and Bridging/Split Tunneling
Are your AP-61s configured as Remote APs or as Campus APs?
